1850 rock shaft seals
Newarkoliver
New User
Repaired my 1850s input shaft and after I had it all back together I noticed both sides of rock shaft leaking. I want to replace the oil seals. Is it as easy as removing 3 point, retaining clip and then driving one seal out from opposite side then the other and replacing.
Do you have a book? Once you take the lift arms off use a slide hammer type seal puller and pop each side off. Remember the lift arm is on the inside.
