White 2-88 Hyd's Get hot
Anonymous-0
We have a white 2-88 and the hyd's get hot fast. The big line on the filter gets so hot in 10min that you cant touch it. Then the dash heat light goes on. We have changed all filters. Any ideas?
Most commonly due to a worn out pump and/or a low main relief valve setting. The low main relief setting will wear out a pump very quickly.
It helps to redirect the pump main case drain into the cooler pump inlet. It's not a fix for your problem, but keeps normal operating temp lower.
