3 pt hitch w/chain stabilizers
This message is a reply to an archived post by DonWi on July 22, 2011 at 03:18:14.
The original subject was "Re: 3 pt hitch wchain stabilizers".
Don,
I found the blocks, which is the best way to mount them to keep from swing the most? Can you put more than one on each side?
Are you using cat1 or 2 thats what makes the differance then also if you want it to swing on the top or bottom.
Almost forgot is the blocks on the arm or tractor?
There is also blocks hooked on the drawbar frame. those are the stabilizer blocks the fat side should be up.on your 3 pt arms there should be first a shim then an adjusting block then a wear plate the blocks are removed for cat 1 and in for 2 .if the sway blocks are on the tractor and if you have the fat side up that should make your imp tight when up and some slack when its down that way if you get to close to something it has some give . if you want email me at [email protected] i can send pics i have tried here and it dont seem to work. also go to tractor parts and look up sway blocks warning sit down before you look at price
