I am working on rebuilding the engine for my 1957 Super55d and am now installing the injection pump. My IT manual says to check the timing marks on the flywheel as there was a running change from 23* to 26* BTDC for the firing point (FP) mark. There is a measurement from the TDC mark to the FP mark of 2-1/2" for the old 23* setting and 2-27/32" for the revised 26* (correct) timing. My flywheel TDC to FP measures at 2-21/32", not close to either. The marks appear to be factory original, there is also a "INT" mark at 25/32" from the TDC mark. The engine has been apart for 10 years after losing a rod so I don't remember where it was timed.
Does anyone have some incite on the best and correct timing setting ?
Mike
Mike
