oliver 880 LP head serial # and cranking compression
jmducks1
What is the serial # of cylinder head for a 880 LP? what is the cranking compression on a LP 880 and a gas? Did they use different heads or get the compression up from different pistons? How do i tell a factory 880 LP from a converted one?
information on tractordata.com only shows a diesel and a gasoline , no lp . maybe someone will answer but it doesn't look like it so far . I'll look in my parts book tomorrow if there is a different head I'll post the part number here . it's the same head as gas and the same pistons.
