TASO
We are getting ready to overhaul our 880 gas this fall and winter. We are curious if the M&W power kits are still available for the 880 engine or are they things of the past?
Does anyone know?
I have been googling around and have not found them.
Thanks.
3 7/8 high dome kits are available at Korves make sure they still have the same compression height as the old flat tops . there is no need in getting a high dome if you lower the compression height .
You will likely be further ahead with 3 7/8 cylinders with flat top pistons and shave the head .050 to .100 to get the extra compression. Get a good valve job with new seats that are set to the proper depth for the new valves. Little things like that can make a big difference in the final results.
