TractorLinks.com
Show Parts for Model:
Re: 1850 Clutch Sticking
super99
08-14-2014 18:12:13
I checked under the bell housing to nite for a plugged drain hole, there wasn't any hole there. There is now, I drill a 3/16 hole thru it and about a 1/2 cup of water ran out. I let it set outside and run for a half hour or so, see if that helps. Chris
oliver90owner
08-15-2014 03:03:06
 Re: 1850 Clutch Sticking in reply to super99, 08-14-2014 18:12:13
It most certainly will! Water trapped in there is not good news!
RAB
oliver90owner
08-15-2014 03:12:00
 Re: 1850 Clutch Sticking in reply to oliver90owner, 08-15-2014 03:03:06
Forgot to add - beware if you go deep wading with the tractor. Maybe thread that drilled hole, for a plug if required?
I think my older Ollies have a drain hole - somewhere for any oil lost through the rear crank seal to be drained away after being thrown off the flywheel, I think.
RAB
