White 2-105
Part Time Pete
As I've posted before, the clutch went away on my 1755, so I "had" to buy a 2-105. Finally got to make some hay with it this weekend, and it works great - uses a lot less fuel than my Oliver too.
Pete
I'll argue that statement. I pulled the same machinery with my 105 that I had for my 1955 at the same speed. The 1955 took 3.5 to 4 gph and the White took 5.5 to 6 gph. The 1370 Case I bought after the 105 didn't take much more fuel and pulled a whole lot more. The Perkins does have a better track record for durability over the Waukesha but that's about it.My 550 MF is also a pig on fuel compared to the 510's we had.
If it an aspirated air cleaner, takes a special stack, if not make sure that stack is 4 ft tall or an elbow to turn away from cab. been running a strait stack since 75 on mine, sounds good though.
