Oliver 70 rowcrop price?
I"m looking at this tractor and I"m trying to figure out what a good price is. It runs good but has a rear main seal leak and I think the water pump is leaking. All the sheet metal is there and in very good condition. Front tires are brand new, rears have very good tread but are mismatched, both rear rims have some rot from calcium. It has a steering issue, very hard to turn. Both rear axle seals are leaking very bad. They are asking $1000 for it. How does it sound? Thanks
I turned one down a few years ago,older restoration with new tires when it was restored,$600 delivered. A guy out east of town bought it after I turned it down. The owner had too many and was selling off the ones he'd had the longest and was getting tired of looking at. I've already got one sitting here in the corner of the toolshed that I've never been able to fall in love with,so I didn't want another one.
Those things just don't bring much.
If both axles are leaking , it's likely overfilled or has water in it , making the oil level rise . pull the plug on the rear end and see how much of what is in it .....
I forgot to mention , there is a steering part called a bell crank that drops down from the top of the tub down to the tie rods . It never gets greased , and is likely the source of the stiffness.You grease it from the rt. side of the lower tub....
