Oliver 99 fan belt
JimKS
Thank you for your responses duane O and JW Schwiebert.Two questions. What is the difference in the belts for the bypass pump and the non bypass pump? What was the problem with the belt from Napa?
Jim
The belt from napa is to long and ment for the early super 99 6 cylinder with the smaller water pump pulley as far as i could tell. It would have fit my1953 99. This belt is 1" wide to fit the adjustable waterpump threaded pulley. As for the bypass pump they used a different pulley top and bottom. This is all from my own findings going through the same situation a few years ago
