Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: OC 4 Diesel fuel in oil pan
cskent
07-27-2014 09:14:02
DGH, there is one way diesel fuel gets into that motor, by the failed shaft seals on that rossa master fuel pump. If it is the same as the ones I have done, there are two "umbrella" shaped rubber seals fairly simple to replace. The most time is spent removing all the lines so you can pull the pump. Get the model from the pump and talk to a diesel shop, see if they can get you the seals, then ask to borrow the little "hot dog tong tool" that aids in installation. I learned the hard way those seals will tear and they go in facing different ways from each other.
