Here"s how I did it as I leave the bale spears on the loader for hauling hay for my horses in the winter time.
is that home made? Looks good.
I was thinking of getting a blade similar to the ones road crews use but the pickup plow might be easier and less expensive.
Your tractor has the same hose clamp on the lift arm mine does. I thought it was just a fix someone came up with, maybe the same guy once owned both tractors. :)
Need to replace my front tires and thought about changing to the tread design yours has.
This works for me. Have to be careful the bucket tilt doesn't drift down & grab the surface. The little Farmi winch on the back helps when I drop a wheel off the side of the road and get stuck.
