Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Oliver 77 Engine install Question
JD5525
07-25-2014 17:06:54
Putting the engine back in after clutch repair.
The I&T manual says 1 front & 1 rear mounting bolt acts as a dowel and must be installed in proper holes. All 4 bolts are just 1/2" bolts and leave some movement side to side & back and forth. How do I make sure that everything is aligned properly? Thanks for the help.
JD5525
07-26-2014 20:16:55
 Re: Oliver 77 Engine install Question in reply to JD5525, 07-25-2014 17:06:54
Thanks RWT. Just needed a simple answer to a simple question. Thanks again!
J. W. Schwiebert-2
07-25-2014 17:21:17
Well first of all you would not had to take the engine out to put a clutch in. Second you need to have 2 (/16 'dowel bolts " which you do not have. Where are you located? There should be many readers on here that have a spare set. More questions? J.
JD5525
07-26-2014 03:19:27
 Re: Oliver 77 Engine install Question in reply to J. W. Schwiebert-2, 07-25-2014 17:21:17
So if I get Two 9/16 bolts, what two holes do they go in?
RWT
07-26-2014 20:12:32
 Re: Oliver 77 Engine install Question in reply to JD5525, 07-26-2014 03:19:27
The 9/16 bolts go in the front left and right rear holes.
RT
Gary Mitchell
07-26-2014 09:18:53
In my experience, if the belt-pulley mechanism is in place on the tractor, removing the engine is the simplest option.
