Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oliver rear axle leak
07-24-2014 16:01:04
Frank, Take the wheel off, then remove the hub, clean the axle, take out the 4 bolts, remove the cap and the seal is right there. before you remove the cap check the axle for up and down movement, if it does move you can fix that by removing a shim or 2 from under the cap, just don't make it to tight. Chuck
