After replacing the coil, points & condensor I got our 880 back running. Something concerns me tho...before I replaced the burned up points & condensor I wanted to see if I had current to the points so I bridged them. It didn't take long to see some smoke & the spring on the points arm started to glow red!! If there were a inline fuse would I still get 12v with less amps? Lets say I put in a 20 amp fuse. Would this be ok? Right now there's nothing & I'm guessing that's why this tractor is so hard on points. How many amps does a typical 12v battery put out? Thank you for your inputs here.
