TractorLinks.com
Show Parts for Model:
Re: 880 gas is alive again
oliver90owner
07-24-2014 04:49:45
DickW is on the money.
Fuses are irrelevant as is current from a 12 volt battery (it could deliver over 500A for the starter motor at initial switching or thousands of amps if short circuited across the terminals).
Seems to me that you short circuited the contact breaker to ground directly from the battery! You perhaps need to understand Ohm's Law before doing thigs like that, if that was what you did.
The coil is an inductive load, but while final current could be 5A, it would have a rising current, the rate of which depends on the time constant of the coil. Average running current would be far less as the dwell angle will also be taken into account.
elkcagg
07-24-2014 05:33:58
 Re: 880 gas is alive again in reply to oliver90owner, 07-24-2014 04:49:45
So when points close...isn't that a direct short?
oliver90owner
07-24-2014 07:10:09
 Re: 880 gas is alive again in reply to elkcagg, 07-24-2014 05:33:58
Most certainly not.
