Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Super and fleet line wide fronts
Josh in Pa
07-23-2014 06:50:07
I have had a 77 with a narrow front for 16 or so years. It steers exceptionally well. I recently bought a super 88 with a wide front. I"ve never driven a steam engine, but couldn"t imagine it steers much worse than the super 88. Steering is heavy and slow, and cranked all the way is not very tight, not nearly as tight as my 16 or 1855. Is this typical or do I have problems? Is there a different ratio for wide front tractors? This seems slower than the 77. Are the stops adjustable? Thanks,
Josh
Jerry P Scheerhoorn
07-24-2014 19:58:32
 Re: Super and fleet line wide fronts in reply to Josh in Pa, 07-23-2014 06:50:07
I may have one of those short turning kismoes in the parts bin, If interested let me. E-mail or 7 one two 7 two nine 3 two four eight This is in nw Iowa!!!
P I Pete
07-24-2014 15:20:40
I bought a 770 during the 70's and put a wide front on it, didn't turn short the local Oliver dealer had a scource to get a short turn block that bolted to the steering arm and extended it toward the rear of tractor about inch and one half, they were made in Henderson, MN if memory serves me correctly. Pete
B A Star
07-23-2014 13:15:08
   When I worked in a dealership way back in the early 60"s we took the center steering arm off and cut it on a band saw and added (can"t remember) either 3/4" or 1".  It made them steer quicker and turn shorter.    Wouldn"t dare do that today with the laws the way they are!
Oliverguy
07-23-2014 11:24:30
Typical, they turn really wide or at least my 88 does. My 1850 turns on dime
CAS
07-23-2014 08:49:23
I do not know what Oliver was thinking with those early front ends. The nice running tractor with those wide front ends it was no selling point.
Larry NEIL
07-23-2014 08:48:59
All the old Oliver wide fronts had the turning problem. In the 70's I used a 880 diesel wide front on a six row narrow planter and had to drag the front end around with brakes every turn.
centralilbaler
07-23-2014 08:02:20
Usually when i turn my Super 88 wf around, i look for the nearest empty 10 acres
J.Wondergem
07-23-2014 07:15:06
If it's like mine, it steers easy, but a lot of turns of the steering wheel and don't turn sharp.
