70 row crop question.
Matt Huls
I am looking at buying a Oliver 70. Did these tractors ever come with spoke wheels on the rear? If so what yr are they produced?
The answer is yes. I couldn't tell you the years they were offered but this was my uncles 37 with spokes and duals.
I have never seen an ad that offered them as options, not sayin they couldn't have been bought somewhere though.
Looke at the casting numbers on the hubs, it was not unusal at all to cut the spokes from steel wheels and weld a rim on them for rubber tires..
I've got the pair in the background on one down back. I never looked for any markings on them,but they're 40s,not cutoffs as far as I can tell. Somebody was saying they looked like French and Hecht,but I honestly don't know if they were factory of if they replaces tip toe's.
I agree Randy, looked at your photo and looks like round spokes that are set into the hub. (fantastic picture) The hub in the looks just like the hub on my 18-27 row crop, but it is on cut-offs.
Sometimes it is easy to tell when the spokes were cut from steel wheels and a pneumatic rim welded in its place. And sometimes it is not so easy...
It took some real skill to weld those thin rims onto those thicker spokes with an old crude AC buzzbox tapped machine stick welder (likely what most shops whether real business or backyard farmer had back in the late 1940's and 1950's).
I have seen some welding rim conversion jobs that were quite crude. On the other hand there were also some real craftsmen back then that took the crudest of tools (in an AC buzzbox) and laid down factory looking welds and looked like the rim was originally built that way. Anyway you slice it is not an easy weld to make with a stick welder without burning through the rim but it can be done if one possesses enough skill and talent. I tip my hat to those old craftsmen on what they accomplished with very little to work with.
rrlund,
Deere also used some round spoked rear wheels for some of their first rubber tires, 36 inch F&H brand wheels? Check on the Deere forum, round spoked wheels for Deere's have some value there.
If that is a the potato digger in the foreground, does still work? When I was a kid we would borrow a neighbor's potato plow, that saved a lot of stooped-over labor.
It's an IH. My Grand dad bought that one new as far as I know. It's been sitting a while but "worked when parked". The cast wheels for the trucks that go under the front got broken a long time ago. It worked good if it was hooked to the 3 point. You could just raise up at the end and turn around with it running.
No,that's a family heirloom. I had to go get it once from a guy who borrowed it and kept it for a few years.
I know I"m a few days late here but I have a 1937 w/round spokes & I"ve been told they were made by F&H for when you converted to rubber they are 36"
pretty narrow maybe 6" wide,they also made front round spokes too & I"d sure like to find a set.
