2050 and 2150 tractor part out
This message is a reply to an archived post by mab570diesel on April 29, 2014 at 18:45:19.
The original subject was "Re: 2050 and 2150 tractor part out".
looking for a steering hydra unit from below the
wheel to the bottom length about 1 1/2 feet. Any
help would be appreciated. Thanks, Don
Someone can correct me if I"m wrong, but if you"re looking for the hydramotor (steering column with big ball on the bottom of it that the hydraulic hoses connect to), then the part number you need is 165815as, and it"s the same unit used on almost any 50 series Oliver tractor, so there is no reason to be searching for this part from a 2050/2150, just go find it from another Oliver, or plug that part number into the web and go from there.
Many discussions on here about upgrading to the 55 series steering motors, you could search for that information too if you like.
1&1/2 feet..hmm does that mean the Saginaw unit and 1/2 or whole steering column that is attached to the unit with a fine spline and taper nut. Or might he be talking about a Charlyn with a different spline and steering column.
If you can find a Charlyn and something goes wrong they are a lot easier to work. Usually nothing goes wrong anyway.
