1750 in 8000# Class
A.P.
Will a 1750 with tricycle front, hydrapower and 18.4 x38" rear tires on pressed wheels be able to make the 8000# class? Thinking of entering a local out of the field farm class tractor pull.
Thank you
I did the same thing a few weeks ago with my 1650, weighed in at 8210 lbs. No fluid, cast centers with two sets of wheel weights, wide front axle, no weights up front. My competition was a Ford 7000, 1850, and a 1655. Both Olivers had 5.9 Cummins swapped in.
Pressed steel wheels without fluid or any other weights might get you below 8000 lbs.
