super 44 hydraulics
d cox
New User
The hydraulics on my super 44 just quit. The pump is circulating oil but I have no pressure. The manual says to remove the unit to the bench to work on it. Does someone know of an easier way to go about it? Thanks for your help.
What do you have for hydraulic test equipment. Remember rule #1, pressure is caused by resistance to flow. So you have an internal leak, now you need to play Sure Lock Homes and find the leak.
Is there any way to plumb air or hydraulics to one of the ports on the top of the unit to reseat the control valve. Call me with your ideas.four 1 nine 77one 000nine Thanks Dennis.
