White 2-70 Hydraulic Question....
donjr
Just recently got a 2-70. It had a loader on it. When you operate the hydraulic levers, it seems to be full flow or nothing- no slow movements. Any way to adjust this?
Second question. Is there a 'float' position on the hydraulic system, where ther is an up-down-float position for a bucket or a piece of equipment, and how and where do you set it?
There's no float. Probably the best thing to do is tap in to the power beyond and put a separate valve on the loader.
Thanks, Randy. I was afraid of that. It's nice to have that 'float' on some of these hills around here. Onct I git this here oilallover figgered out, meebe I'll lack it better.....
You can also take the detent balls out of the valve. Did that on our 1555 to allow partial movement without having to PULL it out of detent.
