should i get it or walk
One thing to keep in mind is that when You open up a diesel engine Open up Your pocket book even wider I bought an 830 Case that had over heated and by the time I was done putting money into it on a factory workers wage I wished I had bought a gasser instead.
Like this :)
that's funny, i followed advice, i had to switch over to classic view to do it, but it worked. now it only shows up in classic view. hmmm
Check out here
http://www.importtractorparts.net/buyersguide.html
I would not be inclined to walk, I would get on my bike and pedal
as fast as possible.
I would call and make sure its not a 1250A, if its a 1250 (4cyl diesel) run away fast, if its a 1250A (3cyl diesel) its not a bad unit but will cost plenty to rebuild.
(quoted from post at 14:04:34 07/08/14) I would call and make sure its not a 1250A, if its a 1250 (4cyl diesel) run away fast, if its a 1250A (3cyl diesel) its not a bad unit but will cost plenty to rebuild.
i called him and he confirmed it was a 4 cylinder so i passed on the deal. oh well, i'll find one, some... day...
