Anonymous-0
Have a 1550 gas with Hydra Power working perfectly. Also have a 1650 parts tractor with very positive crankcase ventilation. The 1550 has to go for a clutch replacement. Could I put the Over Under from the 1650 into the 1550. The overdrive would be excellent for road use and some field transport. Would everything bolt up? What should I have done to OU unit prior to installation? 1650 has not run for 10 years or so. I have no idea if it works. a
As I said, the HP is perfect. I changed the oil and filter in it. Any way I can check the OU unit? I am paying shop rates for this hobby. All answers appreciated.
