Instrument panel bulb removal White 2-135
Anonymous-0
Has someone changed the bulbs in instrument panel on a White 2-135. The air cleaner restriction bulb is bad I have removed the 8 screws that hold cluster and tried get access from behind but it will not move far enough. Or do the red lenses screw out? This is not a series 3. thanks
I don't remember how they come out. Im guessing the reason the panel doesn't come out far enough is because of the tach cable. That is what was holding the one on my cousins 135.
