TractorLinks.com
Show Parts for Model:
Re: 310 turbo overhaul
Josh in Pa
07-02-2014 12:46:07
You should use the 1 piece bushings. I am not sure if the 2 piece are available anymore anyway. Also 12 point rod bolts. Is this an oil cooler block?
Josh
jasinpa
07-02-2014 19:42:09
 Re: 310 turbo overhaul in reply to Josh in Pa, 07-02-2014 12:46:07
it has an add on cooler mounted in between the filter & filter housing , do you have any part numbers for one piece bushings , have looked them up in my FM book but every number i come up with that is close size to use in discontiued , also has anyone ever tryed putting an oil cooler on the turbo return line sence heat from turbo was the problem to start with , something simiar to the hyd coolers infront of rad. engine was blown up back in the day , i know that so most upgrades have been made like 12 point rod bols , cooler , ect. but it never hurts to make things better yet , be nice to have a bigger oil pan , 2 gals. isnt enough because of heat problem , started with a blown head gasket now its a major overhaul because some jack@ss put 3 non turbo liners in it , block needs a counter bore repair sleeve , head was beaten at sealing ring & so on
