My PTO lever is on the R side. When using it with the NH 404 Crusher I would push the lever full forward, and it would slip into the detente locked position. When I lowered the crusher to the ground with the R hydraulic lever, the PTO lever would pop out of the detente position and I would have to hold it in to keep it engaged. If I lowered the crusher with the hydraulic lever to only part way down, the PTO lever would stay engaged. What is going on here? Needless to say it was a PIA when crimping lodged alfalfa, having to hold in the PTO lever and needing to frequently raise the crusher out of the lodged crop to keep rollers from slipping.
