Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Oliver 1650 Diesel (IDI) Pump Removal Timing
J. Schwiebert-2
07-01-2014 17:39:02
Since you already have the lower plate off of the bell housing turn the engine till you find TDC. They were equipped with a "timing tape" marked in degrees. Clean that good! Your pointer is on the front side of the flywheel and can been seen when the inspection cover is removed on the right side od the engine. You need to remove 1 5/16 inch cap screw and then remove the cover. The pointer will be visible then The TDC mark will also be visible.
