Injector lines
Any diesel injection repair shop can make new ones for you if you have the old ones so they can match them up.
Need more details here. There were 3 different sets of lines. The first one that lay down flat. The second set is the most common and then the third set which is for the Super 77 with key start. They might all be used with the Y version of the PSB pump.
Thanks for the info. The line that is to the rear cylinder is not original so matching is an issue, but I can probably work that out.
