I have an Oliver 1850 with a Perkins Diesel engine that we were using this last weekend at a show to pull the people shuttle. So basically the engine had little to no load at all and running low rpms. When I noticed some oil up on the muffler rain cap and them some splatters on the hood. I first thought it was moisture but 30 minutes later someone stopped me and said that there is oil on the side of the engine block. It appears that all of the oil is coming out of the exhaust manifold. I did shut the tractor down and there was still oils showing up on the dipstick and the engine still had good oil pressure. Does anyone have an idea what the problem is before I pull the head and look inside. Would it be a valve guide seal or maybe a broken oil ring?
Thank you in advance for your assistance in this matter.
