2-135 hydraulics
is there more than one hydraulic pump on a 2-135 white? I have good power steering and brakes but can't get the think to raise or lower my disc mower. disc mower is one way cylinder. had the line in the top hole of the inside remote and it's worked just fine for about an hour. then would not let it go down. switched to lower hole on same remote seemed to work good for hour or so and then switched to lower hole on outside remote. worked about 10 min and would hardly even lift the arm.
