SteveGr
Does anyone know if the over-under in a White 140 the same as the one in a 2-135 or 2-155. I need some parts such as the countershaft, carrier gear, and planetary housing.
I believe that would have the heavier over/under not sure. If it does it would be the same as a 155/180. If its the smaller one its the same as a 105/135. Get some part numbers off agcos website then you will know what it has for sure.
