1755 tranny
If you mean the MAIN transmission/rear axle it takes 80W90 GL5 gear lube. My recollection is 44 quarts. Check plugs are to the left of the PTO. Not below lower plug, and not above top plug. If you mean the Over-Under 4 quarts of Dexron III ATF.
