I've got a 1955 Super 88 (S/N 10246), but I think it has got a bunch of different engine parts on it. The block is a K100C, which seems to be from a 88. The carb is a Zenith 12259 and the intake is a 101337A, both of which seem to be from an 880.
The problem I'm having is that in order to get it to run, I've got to have the air screw all the way in and the choke about 1/2 way out. I put a new carb kit in and that didn't seem to help. So, I was planning on putting in a new or reman carb, and in trying to find the right carb for it I found that it seems to have a bunch of different parts on it.
So my question is, if it really is a 880 carb on an 88 block, could that be causing me problems? If I put a new 880 carb on it (with 2 5/8 c-c bolt holes to match the intake) will that help it run better? Or is that carb a bad match for that block?
Thanks for your help.
