77 Hydraulics
I installed a two lever hydraulic system on my 77. All the holes lined up fine but oil leaked into the transmission case. I pulled it out and replaced all four seals on the pump. It still leaked oil. I"m pulling it now for the second time. I"m having trouble getting the shaft out. Can the shaft be pulled (with the clutch) without removing the cast iron case? I can"t remember how I did it the first time since it was like 15 years ago. I don"t use the hydraulics often so the leak didn"t bother me. Now I"d like it fixed.
PTO shaft? Yes. Just take the 3 bolts out of the flange. You'll probably have to use a little force to break it loose after you get the bolts out.
