Injector pump timing on a Super 55 Diesel
Do you have the pump off? Do you have the injectors out? If not is the valve cover off? If not there you need to remove part of the first energy cell. You need to get the engine so number one cylinder is coming up on the compression stroke. You need to find the F P mark on the flywheel. You need to removing the timing window on the injection pump and find the marked tooth. You also need to fine the correct scribe line on the injection pump drive hub first. Remember the pump runs at engine speed so you need to be able to see all 3 timing marks. Start there. You have a phone number and I will walk you the nitty gritty. I will be gone the rest of today and tomorrow.
