clutch won't release on 2-85 white
oliwhite
New User
Replaced clutch,presure plate, release bearing and sleeve on my white 2-85 adjusted fork to 3/4" pedal travel and clutch hardly releases what else should I look for?
Could be you have the wrong pressure plate. I believe that some are for the .125 step in the flywheel and some are not. I think it needs to come back apart.
I think you mean you adjusted the clutch adjustment on the rod that goes to the clutch throwout yoke and bearing.
Did you check the clutch finger adjustment after tightening up the pressure plate. Have found them needing readjustment after tightening pressure plate to flywheel.
Possibility is fiber clutch and botton clutch use two different pressure plates. Either way it probably has to come apart again.
