WI Dave
I"m going to pick up the 3241 plow I posted about the other day. Could someone post or e-mail me the pages from the manual for adjusting the width of the cut? I can"t wrap my head around how you can change it from 12-16" without changing the shares or something. I"ve heard they are great plows, though. Thanks!
If you have 16" shares, you can use any of the widths. Part of the share will overlap the others. If you have 12" shares, spreading it out to 16" will cause issues. I have a manual at home. Still took a lot of head scratching to make sure everything was in the correct spot. Hope your fasteners come apart easily!
Should have mentioned, we have a 2 bottom and a 3 bottom. They are heavy plows! Even with two guys, had to roll the 2 bottom up the ramp of my trailer. Couldn't even drag it! Got the 2 bottom for a steal ;)
Dave, The best thing to do is order a setting up, operating instructions and parts book from the Floyd County Museum @ 641-228-1099. Doesn't cost much and you will have it in a few days. This is what a 3241 looks like. Chuck
If you look at the bolt holes in th picture the frther you push it together the narrow it gets also have to move holes on side together
