TractorLinks.com
Show Parts for Model:
Re: delay in pto and brakes engaging on 1855
2-stroke dd
05-26-2014 20:04:40
The part Cas is referring to is a square block that is bolted to the top of the trans. housing. It is just a tee block where the low pressure supply line goes in and the brake valve line and the PTO pressure line comes out. It is possible something could be caught in there but that would be very unusual. The first thing and easiest thing to check is the PTO pressure. The control valve assembly is located next to and below the hyd. pump. The different valves are labeled. Usually when the pressure is low the PTO will kick out when you apply the brakes.
Cas
05-27-2014 12:12:04
 Re: delay in pto and brakes engaging on 1855 in reply to 2-stroke dd, 05-26-2014 20:04:40
You got that right. Never saw that problem before or after. I would definitely do your procedure first. Forgot to mention thats what I did.
