TractorLinks.com
Show Parts for Model:
Re: Setting valves on Oliver 70
hunt
05-26-2014 18:33:07
There are several methods for adjusting valves depending on the make and model of engine. On engines were the manufacture does not give a specific sequence I always use the valve overlap method on companion cylinders. For example watch both valves on #6 cylinder as the exhaust is almost closed the intake will begin to open both valve rockers should be tight. That is valve overlap and the valves on #1 cylinder would be ready to adjust. Follow the firing order after this to determine what valves will be adjusted next. Number 5 cylinder will be next to be adjusted while valve overlap will take place on #2 cylinder. This method allows you to adjust all the valves in 2 revolutions of the crank. It basically puts the cylinder you are adjusting near top center compression stroke.
