Have been having problems with the pto not engaging right away. It has a significant delay and it doesn't really matter what the engine speed is. I use this tractor for my smaller sprayer which is pto driven. Checked out the sprayer pump and there is no real resistance. While spraying the other day, I noticed that the brakes do not engage right away either. Ended up pulling the boom out of the socket on one case and fixing the end nozzle on another. The pedal seems to go all the way down and then eventually will pressure up to where the brakes work normally. Any suggestions as to where I should start.
