TractorLinks.com
Show Parts for Model:
Re: jumping out of gear
B A Star
05-25-2014 21:19:53
  Your 1550 has a sliding spur gear transmission.  Does it only jump out of 3rd. gear?  The drive and driven gears must line up so the gears are centered on one another.  Take the transmission cover off and check to see if both gears are centered.  Look at the bottom shaft.  You could have a shifting fork that the bolts that hold it to the shifting rail are loose, or the fork is bent not moving the gear to it's proper position.  Also the bolt holes in the fork are slightly oversize, thus you can move the fork soom.  Also check for shaft bearings that have gained too much bearing clearance causing the gears to not be centered.
bison
05-25-2014 22:32:48
 Re: jumping out of gear in reply to B A Star, 05-25-2014 21:19:53
could be just a worn shifter shaft detent ball or broke ball spring or loose fork hold down bolt.
Take the cover off and have a look see
