TractorLinks.com
Show Parts for Model:
Re: hydrapower drive test?
J. W. Schwiebert-2
05-25-2014 15:37:23
We used to run them with a half inch drill and check both the lube pressure and the clutch pressure.
greg oliver
05-25-2014 18:14:51
 Re: hydrapower drive test? in reply to J. W. Schwiebert-2, 05-25-2014 15:37:23
Thank you Mr. Schwiebert, I can turn input shaft only one way is that correct? Hydrapower drive unit has oil cooler on top if that makes any difference. I found an old clutch to use splined hub to make adapter for the drill. Tractor was purchased at auction so don't know it's history but looks pretty good for 7900 hours! Where would you look first on unit that's in tractor now? Thanks again Greg
J. W. Schwiebert-2
05-26-2014 05:09:21
 Re: hydrapower drive test? in reply to greg oliver, 05-25-2014 18:14:51
Take the side cover off of both of them. There are serial numbers on those hydra power units. Check them.
