Mike(NEOhio)
- Location
- Newbury, Ohio
Working on the front axle. Are the two large nuts on the front end of the stay rod supposed to be tight? Where can I get new bushings for the axle pivot pin?
Can someone tell me how to adjust the tension on the lift control lever. It wants to return to raise on it's own. The parts book shows a nut on the shaft but it looks like it's inside the bottom of the left hydraulic control lever. Do the levers have to come out to adjust it?
