Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: #4 Injector line on Perkins
LStangle
05-24-2014 18:33:40
I get white smoke, but if I crack the line to #2 injector it goes away...seems as though # 2 isn't burning completely not sure why...
mkuhns
05-24-2014 18:45:24
 Re: #4 Injector line on Perkins in reply to LStangle, 05-24-2014 18:33:40
Sounds like you have an intake lobe issue with the cam not allowing enough air into the cylinder. Raw fuel will eventually build up in the cylinder and burn when it can causing your knocking. Another thought, is something in the intake manifold port blocking the passage? I forget the head port design. White fuel smoke is lack of compression/air causing delayed or no ignition of fuel.
Copyright © 1997-2015 Yesterday's Tractor Co.
