TractorLinks.com
Show Parts for Model:
Re: #4 Injector line on Perkins
mkuhns
05-24-2014 16:54:31
Just start it up and watch rocker arm movement. It should be more than noticeable if the cam is bad. Do you have any abnormal smoke or unusual noises.
LStangle
05-24-2014 18:33:40
 Re: #4 Injector line on Perkins in reply to mkuhns, 05-24-2014 16:54:31
I get white smoke, but if I crack the line to #2 injector it goes away...seems as though # 2 isn't burning completely not sure why...
mkuhns
05-24-2014 18:45:24
 Re: #4 Injector line on Perkins in reply to LStangle, 05-24-2014 18:33:40
Sounds like you have an intake lobe issue with the cam not allowing enough air into the cylinder. Raw fuel will eventually build up in the cylinder and burn when it can causing your knocking. Another thought, is something in the intake manifold port blocking the passage? I forget the head port design. White fuel smoke is lack of compression/air causing delayed or no ignition of fuel.
