fixing parasitic draws on battery
jim_uny
i am fixing some battery draining applications.
i found these videos very helpful.
http://www.youtube.com/watch?
v=KF1gijj03_0&feature=kp
http://www.youtube.com/watch?v=YYM3P4vyBtw
I've had good luck using those $12 quick disconnects to isolate the a battery's ground terminal when it's not being used.
i agree w/ you and just bought another. after viewing video disconnect should be on negative side.
http://www.jegs.com/InstallationInstructions/700/710/710-74104.pdf
We put disconnects on most of our tractors, but we use a 600 amp panel mount switch with a lever on it, and mount the in a location that somewhat hides them. A starting system is only as good as it's weakest connection.
