Oliver 64 Grain Drill
Emil Nelson
New User
I just purchased a grain drill and was wondering if anyone knew what the fertilizer settings are. I have the chart for the seed and grass hoppers but nothing for the fertilizer. Any help would be greatly app. thanks Emil
I've got 2 of them and one is in good shape and I use it. About the most accurate drill I've ever been around and more accurate than the JD 8300 I used to have.
If I can remember, I'll take a look at mine and check the book on iot tomorrow.
Mine has a chart on it that is readable. If you tell me about fertilizer you want to put on, I will tell what sprocket to use and what noych to put it on.
(quoted from post at 17:31:07 05/16/14) Mine has a chart on it that is readable. If you tell me about fertilizer you want to put on, I will tell what sprocket to use and what noych to put it on.
Thank you for the reply I'm applying Potash. F S said I should be looking at 100 lbs per acer I have one other question and that is do you know where I can buy a coulter The bearing is locked up on one of mine. I'm going to take it apart tomorrow and maybe I can just get a bearing. Thanks again Emil
I went and checked my chart and set on notch 2 with a 10tooth sprocket will put on a 100 lbs.Set on notch 4 with a 6 tooth sprocket will put on 110 lbs. per acre. Hope this helps.
(quoted from post at 18:36:35 05/18/14) I went and checked my chart and set on notch 2 with a 10tooth sprocket will put on a 100 lbs.Set on notch 4 with a 6 tooth sprocket will put on 110 lbs. per acre. Hope this helps.
Thanks that information is just what I needed. Looks like the weather is going to be nice this week. If so Wed i'll see how it goes. thanks again Emil
