UP Oliver
I am replacing the quad rings on my 1755 PTO unit. I have 2 questions.
Do I have to take the whole PTO unit apart to do this? I have the unit off the tractor right now.
If I need to take the stub shaft out, how do I do that? My manual just says remove it, but I see no way of doing that.
Thanks in advance for the help.
Be sure you replace the seals on the clutch brake piston, it is known to cause leakage from hydraulic system to transmission.
