Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
1755 Snap Ring
UP Oliver
05-10-2014 10:42:47
I have my power steering cylinder out of my 1755, and I have the pinion out of the cylinder. I want to take the puller bolt and thrust washer out of the inside of the pinion, but I don't know how to handle that snap ring; it has no holes in the end for me to grab it with my pliers.
Any tricks or ideas would be appreciated.
05-10-2014 18:47:51
 Re: 1755 Snap Ring in reply to UP Oliver, 05-10-2014 10:42:47
If it is the kind that I am thinking of, one end comes to a point that gives you room to work a screwdriver under it enough to get a second one in and then chase it around.
UP Oliver
05-11-2014 05:55:48
 Re: 1755 Snap Ring in reply to showcrop, 05-10-2014 18:47:51
Thanks. That is what I was doing and just wondered if there was a better way. I'll give that another shot. Thanks again.
05-10-2014 14:54:58
Use a hand drill and put a couple of holes in it.
UP Oliver
05-10-2014 18:08:46
 Re: 1755 Snap Ring in reply to Kell, 05-10-2014 14:54:58
Is that what you did?
05-10-2014 19:22:22
 Re: 1755 Snap Ring in reply to UP Oliver, 05-10-2014 18:08:46
The PTO bearing on Fords has the same type of ring, hard to get out so I put a hole in it for next time. But that's cast iron. That gear may be case hardened unless the ring groove is well above the top of he gear teeth.
